Camshaft lobe lube?
5.0L • MANUAL
NMCBRIDE13
In your video series on how to build a 302, you mentioned putting thick, dark grey assembly lube on the lobes of the camshaft. Is this necessary for a roller cam as well? Or just flat tappet? I have lube for the bearings.
Aug 5, 2026 at 3:18 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Record the camshaft and lifter part numbers and obtain their installation instructions. Use the specified lubricant on each surface; do not assume a flat-tappet lobe treatment applies to a roller assembly simply because it appeared in a build video. Ask the machine shop to confirm the final cleaning procedure, including oil passages, thorough drying and protection of bare machined surfaces. If you cannot clean and dry the passages reliably, having the shop complete that step is a practical option. Choose equipment for the required job rather than an arbitrary compressor pressure, and use proper eye protection and safe air-cleaning equipment. Getting lubrication and final cleanliness settled before assembly is a manageable step that helps protect the work already invested in the engine.
Guidance references and applicability
COMP Cams: Lifter installation instructions https://www.compcams.com/pub/media/productattach/c/o/comp4-116_1_.pdf Illustrates distinct preparation requirements for flat-tappet and roller arrangements. Follow the instructions for the actual camshaft and lifters; this does not identify the linked lubricant or specify a block-cleaning compressor.
Read the replies · Discussion summary and reported outcome
  • 55,732 POSTS
It is not as necessary on roller camshafts but I would put it on there anyway because the roller still needs to "mate" to the camshaft. Thanks for asking!
Aug 5, 2026 at 12:25 PM
NMCBRIDE13
Thank you. What is that stuff called?
Aug 5, 2026 at 12:46 PM
  • 55,732 POSTS
No problem, here it is on Amazon.
https://amzn.to/4q4r2XR
Let me know how it goes.
Aug 6, 2026 at 5:32 PM
NMCBRIDE13
I have another question. I am getting ready to give my block a wash within the week after it gets back from the machine shop. Can I use dawn dish soap? And if I don’t have an air compressor, what are my options on drying it off?
Aug 15, 2026 at 6:32 AM
  • 55,732 POSTS
Yep, you can use dawn dish soap. You need compressed air to blow the water off of the block so you can coat it down with WD40 to help stop rust. This is a must, here is an air compressor for ya for $142.00
https://amzn.to/4iai6On
Aug 15, 2026 at 6:51 AM
NMCBRIDE13
Thank you. I also found a 3 gallon 110 psi at harbor freight for 57$. Would that work or is there a specific psi requirement?
Aug 15, 2026 at 7:25 AM
  • 55,732 POSTS
Nope, you are good. As long as you get the water off of the block you should be good to go, enjoy the engine build!!
Aug 15, 2026 at 9:53 AM
Discussion summary
Camshaft lobe lube?
The owner building a Ford 302 asked whether a roller cam needed the grey lubricant shown for cam installation, then asked about cleaning and drying the machined block. Replies suggested products and compressed air, but the actual cam and lifter instructions were not identified.
Reported outcome: No completed assembly or startup result was reported.
The linked products were not evaluated. The camshaft specification and machine-shop cleaning requirements were not supplied, so no universal lubricant or compressor specification is given.
Read the original discussion
