Cam index after head gasket
140,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
YETIFORD1
  • 8 POSTS
2.2ecotec swapped head gasket on daughters car because of a broken timing guide (heads fine did not bend any valves) had her boyfriend "helping" caught him spinning cams with a ratchet. My question is can I just index them normal or do I need to do something different when I put the timing back together? I am thinking its okay, but I know what is likely to happen if I am wrong. Thanks
Jul 1, 2016 at 9:34 AM
HMAC300
  • 48,601 POSTS
if the engine was at tdc when this was done then the valves WILL hit the pistons.if not then try to set it up, if sprocket bolts were removed they should be replaced.
Jul 1, 2016 at 11:53 PM
YETIFORD1
  • 8 POSTS
Yeah the head was on my cleaning cart at the time I figured I could just put it on the car indexed and be OK just wanted a second opinion and we got a complete chain kit bolts included thanks for the reply
Jul 2, 2016 at 1:18 AM
  • 55,797 POSTS
You should flip the head over and pour some light oil in the combustion chambers to see if any of the valves got bent while it was on the bench.
Best, Ken
Jul 8, 2016 at 11:27 AM
