Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Accord
Engine
Camshaft
Bolt
Torque
What are the Cam bracket bolts torque specs?
1995 HONDA ACCORD
200,000 MILES • 2.2L • 3 CYL • AUTOMATIC
WAT2CPRO
MEMBER
1 POST
I need to know the torque specs for the Cam Bracket bolts and cam pulley.
May 27, 2025 at 7:06 AM
Experienced Mechanic
Sure, this is what I found.
Camshaft Bracket Bolts (Camshaft Holder Bolts): Torque: 16 ft-lb (22 Nm)
Camshaft Pulley Bolt: Torque: 27 ft-lb (37 Nm) Then turn an additional 60 degrees.
Let us know if you need anything else.
May 29, 2025 at 3:55 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
