What are the Cam bracket bolts torque specs?
200,000 MILES • 2.2L • 3 CYL • AUTOMATIC
WAT2CPRO
I need to know the torque specs for the Cam Bracket bolts and cam pulley.
May 27, 2025 at 7:06 AM
  • 55,711 POSTS
Sure, this is what I found.
Camshaft Bracket Bolts (Camshaft Holder Bolts): Torque: 16 ft-lb (22 Nm)
Camshaft Pulley Bolt: Torque: 27 ft-lb (37 Nm) Then turn an additional 60 degrees.
Let us know if you need anything else.
May 29, 2025 at 3:55 AM
