Need the exact location of the camshaft and crankshaft position sensor?
100,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
  • 239 POSTS
Need the exact location of the camshaft and crankshaft position sensor-Ty
Sep 16, 2022 at 8:32 AM
  • 55,743 POSTS
Both the camshaft sensor and the crankshaft sensor are on the front of the engine. The crankshaft sensor requires the removal of the timing belt and cover. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Sep 19, 2022 at 6:12 AM
