Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Mighty Max
Engine
Camshaft
Timing
What is the Cam and Crank alignment?
1994 MITSUBISHI MIGHTY MAX
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
MEMBER
Need to know the exact position of the cam and crank timing position while at TDC compression stroke. Thank you
Oct 31, 2021 at 2:34 PM
Experienced Mechanic
I am attaching the entire process including the timing marks for your review.
https://www.2carpros.com/articles/serpentine-belt-timing-belt-timing-chain-diagrams
Please see below for the entire process. Please run through this info and let us know what other questions you have.
Thanks
Images (Click to enlarge)
Nov 1, 2021 at 4:49 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
