I broke the bleeder valve, and I am trying to use extract it before replacing the entire caliper. Is it okay to spay it with some kind of rust penetrant? (The caliper is fully removed, and I will have to bleed all the brakes later)
Also, when cleaning the slide pins, I am replacing the slide pins and boots. Can I use brake clean inside where the pins go for a better clean and then lubricate once dry?
Dec 13, 2022 at 2:31 AM
