Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Fusion
Brakes
Pads
Front
changing my brake and rotors
2016 FORD FUSION
65,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
DON MAYFIELD
MEMBER
1 POST
Okay, I was changing my front brake and rotors and found I need instructions can you help me please?
Nov 19, 2019 at 9:00 AM
Experienced Mechanic
The subject states you need front pads but then you said you need rear in the body of the post so I am going to provide both.
Here are some guides that will help with this: This video shows the job being done on a similar car but the process is the same.
https://youtu.be/dlIUJOYnYQc
and
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Below you will find the detail from the manual. Please let us know what questions you have. Thanks
Images (Click to enlarge)
Mar 11, 2021 at 10:13 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
