Caliper guide pin removal
135,000 MILES • 3.4L • V6 • 2WD • MANUAL
BMEGONIG
  • 6 POSTS
I have 2 stuck caliper guide pins on the front passenger side. Need to figure out how to get them off? thanks
Feb 25, 2020 at 1:57 AM
SCGRANTURISMO
  • 4,897 POSTS
Brakes do not have guide pins. The caliper should be held on with two bolts. If the bolts are stuck then I would recommend spraying them liberally with WD40 or PB Blaster and letting them set at least 15 minutes to 1/2 hour. Then if they are still hard coming off, get a length of pipe that your ratchet handle or wrench will fit in to. This will give you leverage and you should be able to break the bolt free. Here is a link to a guide that should help:
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Please keep us informed and I hope that this helps.
Thanks,
Alex
2CarPros
Feb 25, 2020 at 2:11 AM
