Cadillac SRX - STS Door Locks
PEAT001
Other Category problem
Cadillac SRX - STS V8 All Wheel Drive Automatic 41750 miles
The drivers door does not catch when closed. The sensor light indicates the Drivers Door is Ajar. Even though the electrical controls will pull done the button, the door will not latch. Is there anything I can do, or do I need to have the lock replaced.
Feb 10, 2008 at 7:08 AM
BUZZSAW
  • 1,198 POSTS
[quote:5f2044421b="Peat001"]Other Category problem
The drivers door does not catch when closed. The sensor light indicates the Drivers Door is Ajar. Even though the electrical controls will pull done the button, the door will not latch. Is there anything I can do, or do I need to have the lock replaced.[/quote:5f2044421b]
if you havent really slamed it shut try lubercating it with white grease spray, other wise the latch will have to be replaced
Feb 11, 2008 at 3:52 AM
