'98 STS AIR CONDITIONING-in FL, PLEASE HELP ITS HOT!
NALV420
Hi, I have a 98 cadillac STS northstar v8 with 160,000 miles on it.
The A/C blows great like the heat, but it won't get COLD. When we tried to put freon (r-134) in it, you could hear something sounding like air leaking out in the front of the car. Please say it's just a hose or something under $1,000 dollars. We had to replace the alternator, which started a fire on some of the wiring harness just last november.
PLEASE HELP!
Jun 18, 2007 at 12:24 PM
MIKE H R
  • 3,094 POSTS
get some a/c leak detecter. it goes in like you would fill with freon. The fire how much damage did it do. was it near the a/c compressor? if it was that bad it may have burnt the rubber o ring seals on the compressor.
Jun 18, 2007 at 2:43 PM
NALV420
We took it directly to the dealer and just some of the wiring was damaged,it was replaced and a new alternator was put in for $1700, everything else was in working order and fine as far as they told us upon leaving.
Thanks for such a quick reply, I realize I should just take the car in and get the diagnostics done on the A/C, I guess I'm just looking for a price range before I go in.
Best case: hose
Worst case: compressor
or no?
Jun 18, 2007 at 4:13 PM
