2004 Cadillac STS keys ignition
2004 CADILLAC STS
48,000 MILES • V8 • 2WD • AUTOMATIC
JIGGSJUNCTION
unable to remove keys from ignition switch
Oct 9, 2010 at 2:05 AM
FACTORYJACK
  • 4,159 POSTS
If the cylinder still turns and starts, rotates through its full range but the key don't pull out, it may be an issue with the ignition cylinder or tumblers inside. If it rotates, you may still be able to withdraw the ignition cylinder from the housing.
Oct 9, 2010 at 6:35 AM
