2002 Cadillac STS Misfire
160,000 MILES • V8 • FWD • AUTOMATIC
SHADYPENZ
P0306 Misfire Code
Have tried....Coil,Plugs,Injector,Intake Gasket,Ignition Control Module....All Cylinders have 175 lbs Compression...Any ideas???
Mar 28, 2010 at 2:10 AM
FACTORYJACK
  • 4,159 POSTS
Sounds like youve tried most possibilities. You could have a broken valve spring, or a follower that came off. You will still have compression, It will possibly build faster. The only other possibility would be to check that the #6 injector is firing, you would need an injector test(or noid) light for that. What condition is the spark plug when you remove it from #6 cylinder, is it wet?
Mar 28, 2010 at 3:36 PM
