2002 Cadillac STS Check Colllent level message
60,000 MILES • V8 • FWD • AUTOMATIC
PIATTPIA
Message off and on. After collent is added, message gowes away. About a month later, comes on again.
Had it checked at dealer, ran pressure test, no leaks evident. Could this be a blown head gasket? Jf so, how much is involved in repair?
Jan 21, 2009 at 12:34 PM
OBXAUTOMEDIC
  • 3,718 POSTS
[quote:89ecf5c98d="piattpia@aol.com"]Engine Cooling problem
2002 Cadillac STS V8 Front Wheel Drive Automatic 60000 miles
Had it checked at dealer, ran pressure test, no leaks evident. Could this be a blown head gasket? Jf so, how much is involved in repair?[/quote:89ecf5c98d]
Did pressure test show a drop in pressure? If not the coolant system is contained and no leakage anywhere.
Have you had any work done to the coolant system prior to the problem starting?
Could also be that the coolant level sensor is going bad.
Jan 21, 2009 at 12:55 PM
FACTORYJACK
  • 4,159 POSTS
Sometimes a pressure test is better if it can run through a cooling down, like overnight. Is there any evidence(dexcool crust) anywhere on the lower engine. A few things come to mind, leaking coolant pump cover, a leaking coolant pump housing(aka crossover) typically rear bank block seal that can be difficult to see, and a blown head gasket due to pulled threads in the block. Have a block test run, to see if there are any combustion gases in the cooling system to indicate an internal leakage.
Jan 29, 2009 at 3:57 PM
