2001 Cadillac STS Steering problems
113,000 MILES • V8 • FWD • AUTOMATIC
AGLIKO
The steering works properly for about 10 -15 minutes after starting the vehicle. After which the steering becomes very difficult and makes a moaning sound. The vehicle has a steering stabilazation system, which means that replacing the rack and pinion could cost up to $1200.00 to replace. could there be another option to fix this problem.
May 23, 2008 at 4:52 PM
MERLIN2021
  • 17,250 POSTS
Is the moaning from the pump? You might want to pressure check the pump...
https://images.2carpros.com/forum/automotive_pictures/62217_PS_1.jpg
May 23, 2008 at 11:26 PM
BUZZSAW
  • 1,198 POSTS
[quote:0a96b703b4="agliko"]Steering problem
2001 Cadillac STS V8 Front Wheel Drive Automatic 113000 miles
The steering works properly for about 10 -15 minutes after starting the vehicle. After which the steering becomes very difficult and makes a moaning sound. The vehicle has a steering stabilazation system, which means that replacing the rack and pinion could cost up to $1200.00 to replace. could there be another option to fix this problem.[/quote:0a96b703b4]
do you have a ck engine light on? ck your codes, a steering wheel position sensor could be the prob
May 24, 2008 at 8:13 AM
