2001 Cadillac STS Right cornering light stays on
110,000 MILES • V8 • FWD • AUTOMATIC
JIMDAILEY
The right side cornering light stays on all of the time. It will go out when the left turn signal is on. It stays on when the right signal is on, but it stays on after turn signals are off.
Oct 8, 2009 at 2:28 PM
FACTORYJACK
  • 4,159 POSTS
A simple circuit for cornering lamps. Fused power goes to the turn signal switch. Two wires, one orange for left cornering, and black for right, leave the switch and power the bulbs. Both circuits share a common ground. My feeling is you have a shorted turn signal switch. If you had the black wire shorted to power, it would not go out when the left is activated.
Oct 9, 2009 at 3:58 PM
