Where is the camshaft sensor located and how do I test for cylinder 6 missfire or repair it. My codes are P0306 and P0340, P0341...
Apr 4, 2009 at 2:24 PM
FACTORYJACK
✓Experienced Mechanic
The cam sensor is in the front(passenger side) of the rear bank cylinder head. Does it run like it's misfiring?, #6 is on the front bank, which is at least easier to get to. You can isolate a misfire by swapping the coils, your misfire would move to #5 and possibly p0305 would set, or swap the #6 plug with another cylinder and see if the code follows.
