1999 Cadillac STS Timing chain tensioners
100,000 MILES • V8 • FWD • AUTOMATIC
SQUEEGEE4LIFE
How do I get the timing chain tensioners to go back in? Is there a way of doing this without taking the timing chain cover off?
Replacing head gaskets!!!
I pressed slightly on the tesioners but they seemed tough to go back in.
Jan 26, 2010 at 9:45 AM
FACTORYJACK
  • 4,159 POSTS
You will need to remove the cover. There is a lever that is used to unlock them, and a pin is shoved in the hole to lock them fully retracted. When that pin is removed, then they spring into place. The pin can be a cotter pin, nail, anything, not a special tool.
Jan 26, 2010 at 1:41 PM
