1999 Cadillac STS starting
WARRENPATTY
  • 5 POSTS
1999 Cadillac STS V8 Automatic 37000 miles
When first starting on chilly and cold mornings, the car runs rough until I drive it for a few minutes and then its fine
Nov 17, 2008 at 10:30 PM
  • 110,244 POSTS
Hi:
Is it only rough at an idle? Also, have you had the computer scanned for trouble codes? Most nationally recognized parts stores will do it for free. Keep in mind, when the weather gets colder, the engine runs richer so you may notice a small difference.
Let me know what you find.
Nov 18, 2008 at 5:16 AM
WARRENPATTY
  • 5 POSTS
Joe, thanks for the reply. The car idles rough and runs rough at a low speed but after a minute or two runs fine. I checked for codes but the ones that i'm getting are for another problem I have put out there ,but have not gotten a reply yet, codes c1281, c1286, c1287. Any thoughts would be greatly appreciated. Warren
Nov 18, 2008 at 10:54 AM
  • 110,244 POSTS
Hi:
Here are the codes and their causes:
C1281 Stabilitrak Sensors Uncorrelated
C1286 Steering/Lateral Accelerometer Sensor Bias Malfunction
C1287 Steering Sensor Rate Malfunction
Based on these, there is a problem with the steering sensor system. Are you having any trouble with drivability related to the steering?
As far as the rough idle at start up, if it isn't too bad and only last a few minutes, I would wait until it gets bad enough to set a code. Otherwise, you'll end up replacing parts that are good.
Let me know if you have any other questions.
Nov 18, 2008 at 11:35 AM
WARRENPATTY
  • 5 POSTS
Thanks again Joe, I had replaced ebtcm and a motor mount because I had service susspention message, I was driving out the dealership when service stabilty system came on, they ran the same codes but said they needed more diagnostic time (money) to investigate. The message went away but twice this week while turning left, I heard a grrrrrrrrrr noise, seemed to loose power , and got a stsbility engaged message all in 5 seconds, then it dissappeared and it runs fine. I all ready spent 2300.00 at dealer and don't want to spend much more. The car has low milage, never been in snow, and is garaged. Warren
Nov 18, 2008 at 10:16 PM
