1999 Cadillac STS RIMS? GO BIG OR NOT?
1999 CADILLAC STS
120,000 MILES • V8 • 2WD • AUTOMATIC
RAISEDONCADDYS
I JUST BOUGHT A 1999 STS & I AM THINKING OF GOING WITH A BIGGER RIM MAYBE A 20. I AM TRYING TO FIND OUT WHAT IF ANY COULD BE THE NEGATIVE EFFECTS FROM THAT?
Jun 3, 2009 at 5:09 AM
2CARPRO JACK
  • 11,533 POSTS
Inaccurate speedo, which can cause issues with the PCM, harsh ride due to low profile tires, premature wheel bearing wear due to extra weight/leverage against it.clearance issues.
Jun 3, 2009 at 5:15 AM
RAISEDONCADDYS
HOW ABOUT UPGRADING TO AN 18 INCH WHEEL DO YOU THINK THAT WOULD CAUSE ANY ISSUES?
Jun 3, 2009 at 5:21 AM
2CARPRO JACK
  • 11,533 POSTS
If aluminum, it wont hurt the bearings as bad.You may need to have the PCM programmed for the different tire height to keep the trans shifting at the right time.
Jun 3, 2009 at 5:23 AM
