1999 Cadillac STS alternator
146,000 MILES • V8 • FWD • AUTOMATIC
WANNABFIXER
I need to replace the alternator in 1999 cadillac sts. What do I need to do to get it out?
Oct 17, 2008 at 12:21 PM
  • 110,248 POSTS
This is a straight forward job. You may have some trouble with clearance, but that should be all. First, disconnect the battery. Next, remove the wiring from the rear of the alt. Now remove the belt. Finally, there are 2 or 3 bolts that hold the alt in place. Remove the bolts and the alt should come out. Reverse the sequence to replace it.
If you have any trouble or questions, let me know.
Nov 18, 2008 at 5:42 AM
