1998 Cadillac STS
RODEJ123
  • 1998 CADILLAC STS
  • V8
  • FWD
  • 64,000 MILES
I just recently replaced the rack and pinion and high pressure line on my 98 Cadillac STS. I had read several things online about it's problems and difficulty replacing it and I actually had access to a lift which made it not that bad to replace. Well when I was all done I lowered it down to fill it up with fluid, I filled the resevior up and started it up, it ran fine for a minute and then I noticed the fluid was being sucked down at a rapid rate, no leaks though, I just figured the pump was sucking it down so I kept filling it, after about 30 seconds it seemed weird because it kept sucking it down. All of a sudden out of nowhere I heard a loud pop almost like a gunshot and fluid starting pooring out of the bottom of the car. I checked underneath and it was definately the rack, apparently it blew its seals. I know it is destroyed and will need to be replaced again, but what caused this to happen, did I do something wrong, did I leave something out, is the rack faulty. What do I need to do to keep this from happening again?
Saturday, August 21st, 2010 AT 10:31 AM
FACTORYJACK
  • 4,159 POSTS
Unless the rack had failed, and all the fluid was being expelled into the bellows boots where the inner tie rods connect, I have never heard of such a thing. Even if the return line was blocked, I don't believe the pressure would blow it apart.
Saturday, August 28th, 2010 AT 2:26 PM
