1998 Cadillac SRX - STS The Transmission is stuck in "
53,164 MILES • V8 • FWD • AUTOMATIC
RICHHADDOCK
I can't move the shift lever out of Park. It's been difficult at times in the past, but this time it's stuck.
Dec 11, 2007 at 4:47 AM
BUZZSAW
  • 1,198 POSTS
[quote:57840a99d9="richhaddock"]Transmission problem
1998 Cadillac SRX - STS V8 Front Wheel Drive Automatic 53164 miles
I can't move the shift lever out of Park. It's been difficult at times in the past, but this time it's stuck.[/quote:57840a99d9]
remove the shift cable off the trans, 13mm bolt, then try to shift from inside the car, this will tell you if it is in the cable or trans
Dec 12, 2007 at 2:01 AM
