1997 Cadillac STS oil light
138,000 MILES • V8 • FWD • AUTOMATIC
123MARUCA
hi just bought 97 sts and did not notice right away but at idle(red lights) the little oil can light flickers???pls tell me it could be some type of sencer or pressure switch.if not what do i do to figure out problum?seems like raising the idle speed would fix but it idles at about 750?i that cars normally idle closer to 1000-1100.also the a/c works fine but once in awhile it switches from dash vents to defrst or floor for a couple minutes and then goes back??the back a/c vents are not affected?
Jun 14, 2010 at 12:24 PM
FACTORYJACK
  • 4,159 POSTS
If you are not experiencing engine noise, then I would start with an oil pressure sensor. In regards to the A/C, I need more specifics. It is possible if you are in auto mode, and the temp selected is close to the ambient or inside temp, it could transition modes.
Jun 16, 2010 at 3:15 PM
