1997 Cadillac STS ANTI THEFT
100,000 MILES • V8 • FWD • AUTOMATIC
HERBMADILL
THE CAR WAS LEFT OVER THE WINTER, BATTERY DIED. PUT CHARGER ON TO BOOST, TRIED TO START. DASH READOUT SAID "THEFT SYSTEM PROBLEM/CAR MAY NOT START - EXP 34". TRIED SPARE KEY. UNABLE TO START. LEFT BATTERY GROUND CABLE OFF FOR AN HOUR. SAME PROBLEM. HOW DO I SOLVE THIS PROBLEM?
May 12, 2008 at 12:10 AM
BUZZSAW
  • 1,198 POSTS
[quote:c1497d9391="herbmadill"]Computer problem
1997 Cadillac STS V8 Front Wheel Drive Automatic 100000 miles
THE CAR WAS LEFT OVER THE WINTER, BATTERY DIED. PUT CHARGER ON TO BOOST, TRIED TO START. DASH READOUT SAID "THEFT SYSTEM PROBLEM/CAR MAY NOT START - EXP 34". TRIED SPARE KEY. UNABLE TO START. LEFT BATTERY GROUND CABLE OFF FOR AN HOUR. SAME PROBLEM. HOW DO I SOLVE THIS PROBLEM?[/quote:c1497d9391]
the ign switch is bad
May 12, 2008 at 2:26 AM
HERBMADILL
Removed ignition switch, tested two wires to theft deterrent system. Both ok. Checked key resistance and verified same at harness connection under steering column. Hooked up obdII code reader and it showed an error 'not comminicating with computer'
May 14, 2008 at 12:49 PM
BUZZSAW
  • 1,198 POSTS
[quote:1eb4236c75="herbmadill"]Removed ignition switch, tested two wires to theft deterrent system. Both ok. Checked key resistance and verified same at harness connection under steering column. Hooked up obdII code reader and it showed an error 'not comminicating with computer'[/quote:1eb4236c75]
what wires did you ck what color were they?
May 14, 2008 at 5:57 PM
HERBMADILL
They were two white wires in an orange plastic casing that came down the steering column from the key switch. The reading between these two wires was the same as the reading across the resistor in the key.
Jun 1, 2008 at 9:07 AM
