When shift lever is in park can hardly get into reverse or drive
Oct 13, 2010 at 2:38 AM
FACTORYJACK
✓Experienced Mechanic
Does the shift knob lever(release) work normally? You could disconnect the cable at the trans and see if it frees. If it does, the fault is in the transmission. If not, it is a fault with shifter or cable.
