1995 Cadillac STS Shifter
1995 CADILLAC STS
53,460 MILES • V8 • 2WD • AUTOMATIC
GRANTCLOGAN
When shift lever is in park can hardly get into reverse or drive
Oct 13, 2010 at 2:38 AM
FACTORYJACK
  • 4,159 POSTS
Does the shift knob lever(release) work normally? You could disconnect the cable at the trans and see if it frees. If it does, the fault is in the transmission. If not, it is a fault with shifter or cable.
Oct 13, 2010 at 3:33 AM
