1995 Cadillac STS ac blower motor
1995 CADILLAC STS
100,000 MILES • V8 • FWD • AUTOMATIC
BIGTROUT
having trouble with my ac--sometimes the i hear the blower motor but rarely!! when i adjust the temp by pushing up or down on the buttons to activate it--whether for ac or heat i just hear a faint sound but no air coming through. what do you think seems to be the problem? i checked fuses and they are ok. how can i access the blower motor--where is it located and what can i check on it???
May 27, 2008 at 2:40 AM
BUZZSAW
  • 1,198 POSTS
[quote:da18dae025="bigtrout"]Air Conditioning problem
1995 Cadillac STS V8 Front Wheel Drive Automatic 100000 miles
having trouble with my ac--sometimes the i hear the blower motor but rarely!! when i adjust the temp by pushing up or down on the buttons to activate it--whether for ac or heat i just hear a faint sound but no air coming through. what do you think seems to be the problem? i checked fuses and they are ok. how can i access the blower motor--where is it located and what can i check on it???[/quote:da18dae025]
the blower motor is on the firewall behind the center of the motor, to get it out you need to tip the motor forward or remove the coil assy and valve cover in the back
May 30, 2008 at 7:49 PM
