I've tried everything I know to get the crankshaft bolt to break loose and it won't! I've tried the breaker bar with a cheater pipe and also an impact wrench! Any suggestions?
Thursday, April 29th, 2010 AT 9:11 PM
FACTORYJACK
MECHANIC
It has an extremely tight torque value since it is the clamping force that drives the oil pump. You should have been able to get it with a breaker bar and cheater pipe. Are you locking the flywheel?
