1993 Cadillac STS Water Pump Replacement
42,176 MILES • V8 • FWD • AUTOMATIC
JALARIC1971
Located in the midwest, what is the average cost to replace a water pump on a 1993 Cadillac Seville STS, 4.9L V8 with NorthStar engine.
Nov 21, 2009 at 6:38 AM
ERNEST CLARK
  • 1,730 POSTS
If you purchase a water pump from a parts store like AutoZone, it'll run you about $50 bucks. The problem is, most shops won't install parts you bought yourself.
They'll tell you it's because they don't want to warranty someone else's part, and they prefer to go through their own supplier.
But the truth is, most shops use a service called Alldata that gives them their repair procedures, as well as labor rates and part prices. And Alldata will quote a price of $150, which is rediculous. But this allows the shop to quote you that price, so they can then go by your water pump from AutoZone for $50 and make an extra $100.
And if they install your bought part, they'll be cutting themselves out of the hundred.
As for straight labor, most shops will charge you $150-$200. But shop around and don't be afraid to tell a shop that someone else is quoting you a lower price.
Feb 20, 2010 at 1:25 PM
KENNY KELLY
If you go the Autozone or Advanced Auto route to buy the water pump (like I did for my 93 STS), unless you take it to a GM mechanic, you may also want to buy the special tool required for the job. I got mine at Advanced Auto for ~15-20 bucks. If you're a do-it-your-selfer... don't even try it without the tool!
Dec 29, 2010 at 2:46 AM
