1988 Cadillac STS Starter
1988 CADILLAC STS
140,000 MILES • V8 • FWD • AUTOMATIC
KENDRICKDK
The car will turn over after it sits for a while, but only for one or two tries. The starter is working fine since I took it off and tested it. I don't think it's the parking switch either. I've replaced the steering column and switch. The battery is very good.
Any ideas? I take pride in the fact that I can fix almost anything but now I'm running out of ideas. I imagine it could be some kind of module or maybe even the computer itself.
Thank you for any advice,
Ken Keeton.
Jan 14, 2009 at 8:54 AM
2CARPRO JACK
  • 11,533 POSTS
Here is a wiring diagram. There is a starter relay(left side of instrument panel) in the mix, so you will have to test through that as well.
https://images.2carpros.com/forum/automotive_pictures/1639_caddy_1.jpg
Jan 14, 2009 at 1:22 PM
