Pulled car into garage last night. Went out this morning to start and it will not crank. Turns over and acts like it is trying to start. Have checked fuses and you can hear the fuel pump sound for about two seconds when you turn on key.
Have OBD II device and plugged in, no codes returned. Also removed cover on engine, found what I believe to be pressure relief for fuel, depressed the valve and no gas or pressure present.
Before I drop the tank, is there anything I would be missing that is a simple problem. Also, while you are responding, any pointers on dropping the tank. It looks like a job. Thanks for your time.
Roger
Roger
Nov 15, 2009 at 6:06 AM
