Have OBD II device and plugged in, no codes returned. Also removed cover on engine, found what I believe to be pressure relief for fuel, depressed the valve and no gas or pressure present.
Before I drop the tank, is there anything I would be missing that is a simple problem. Also, while you are responding, any pointers on dropping the tank. It looks like a job. Thanks for your time.
Roger
SPONSORED LINKS
Sunday, November 15th, 2009 AT 2:06 PM
