2005 Cadillac SRX DTC codes
WHY
Computer problem
2005 Cadillac SRX 6 cyl Front Wheel Drive Automatic
If you can, How do you access the onboard diagnostics,so you can research the codes.i thank-you for your help .
Jun 25, 2008 at 2:36 PM
F4I_GUY
  • 3,302 POSTS
VIA the DLC which is on the left side of the dash. It's to the left of the steering column. You will need a code reader to retrieve codes.
Nov 28, 2008 at 5:08 PM
