2004 Cadillac SRX power steering too tight
89,000 MILES • 6 CYL • AWD • AUTOMATIC
ATLEE
My Power steering hose got a hole in it and we replaced the hose, now it is so tight you have to do a 5 point turn to get out of a parking spot.
is it a air pocket problem or the power steering pump?
Aug 4, 2010 at 11:28 AM
FACTORYJACK
  • 4,159 POSTS
Do you have any noise, and have you checked the fluid level in the reservoir? If it is low, you should have noise. If it is really low, you will have no assist, and no noise. Even if you had air in the system, the pump should cavitate, and that makes a growling noise when it happens. It could also have a failed pump, it does not take them long if run low, to burn up.
Aug 4, 2010 at 4:07 PM
