2003 Cadillac SLS losing coolant
2003 CADILLAC SLS
LRICH400
Heater problem
2003 Cadillac SLS V8 Front Wheel Drive Automatic
coolant loss was diagnosed as "crossover" line, I believe between the water pump and block, have to remove most of components on right side of engine, approx cost - $900+, 6.5 hrs labor. Have you heard of this problem, ant if so is this a reasonable price from the dealership.
Sep 23, 2009 at 8:01 AM
FACTORYJACK
  • 4,159 POSTS
The coolant pump housing seals do leak. The labor time is in that range. Parts may include crossover seals, dexcool, egr gasket, throttle body seals, plenum boot, pump cover seal, water pump, etc... There is variations among technicians, but you are in the ballpark.
Sep 23, 2009 at 2:47 PM
