2003 Cadillac SLS jump starting battery
2003 CADILLAC SLS
48,000 MILES • V8 • FWD • AUTOMATIC
RICHREED29
where is the battery located
Aug 16, 2009 at 7:28 AM
FACTORYJACK
  • 4,159 POSTS
Battery is located under the rear seat cushion, on the passenger side. Firmly lift on one side of the seat cushion, and then the other side, to release the retainers.
Aug 18, 2009 at 12:01 AM
RACEFAN966
  • 5,029 POSTS
The battery is under the rear seat but that is not how to jump start it. Under the hood on the passanger side there is a plastic cove with a + sign on it lift the cover and you will see a stud. That stud is for the possitive side to hook to. Now the - side or ground goes to a good known ground under the hood and you can jump start it. I tried to find a pic but could not so hope this helps. If you need a pic let me know and I will try again.
Aug 27, 2009 at 12:03 PM
