2003 Cadillac SLS hvac blower doesn't work consistently
90,000 MILES • V8 • FWD • AUTOMATIC
RRBUCHANAN
The ac blower does not start and run consistently with either the heater or AC system. The fan will run sometimes and not run others. Totally random.
Doesn't appear to be related to temperature control system or ambient conditions. Fan does not make noise when it runs, and no noise (hum like its stalled)can be heard when it doesn't start.
When using the AC, the compressor will continue to cycle if the ac system is turned on. AC function switch position has no impact.
Aug 8, 2009 at 7:45 AM
FACTORYJACK
  • 4,159 POSTS
Under the rh side of the dash is an insulator, remove that and you will have access to the blower motor. It is a two wire connector, large wires, I believe purple and black. If you have a test light, check across the two terminals when it fails to run, if it lights you need a blower motor. You might even try just tapping on the motor with a screwdriver handle or similar, and see if it starts up also.
Aug 8, 2009 at 11:12 AM
PAAKWESIA
[quote:ebbdfa5312="rrbuchanan"]Air Conditioning problem
2003 Cadillac SLS V8 Front Wheel Drive Automatic 90000 miles
I have a 2002 Sls that i am working on and it had the same problem I found the problem was that the connector that connects to the ac blower gets loose so you can either redo the connector with a repair kit. I hope it helps out
When using the AC, the compressor will continue to cycle if the ac system is turned on. AC function switch position has no impact.[/quote:ebbdfa5312]
Apr 1, 2010 at 5:13 PM
