THE MASTER WINDOW CONTROL DOESN'T WORK... OTHER WINDOWS WORK WITH THEIR SWITCH... COULD THIS BE A SWITCH PROBLEM OR FUSE/RELAY ISSUE? THANK YOU.
Feb 27, 2010 at 10:53 AM
FACTORYJACK
✓Experienced Mechanic
If no windows work from the left front door switch, I would check the DRV/MDL fuse in the rear fuse block, maybe even remove it and reinstall it. You can also swap the front door modules from side to side. The switch just feeds info to the door module, it performs the commands. There could also be wiring issues where it passes out of the door to the body.
