2001 Cadillac SLS Starter
MROCHA1988
2001 Cadillac SLS Automatic 57000 miles
How do i replace the starter on my 2001 Cadillac SLS?
I know its inside the manifold, but i don't know how to get to it.
Jan 13, 2010 at 6:26 AM
  • 75,988 POSTS
Notes STARTER MOTOR REPLACEMENT REMOVAL PROCEDURE
https://images.2carpros.com/forum/automotive_pictures/12900_s1_25.jpg
Disconnect the battery negative cable. Remove the intake manifold. Disconnect the BAT cable from the starter. Disconnect the wire from the "S" terminal on the starter.
https://images.2carpros.com/forum/automotive_pictures/12900_s2_24.jpg
Remove the two starter motor mounting bolts. Remove the starter motor. INSTALLATION PROCEDURE NOTE: Refer to Fastener Notice in Service Precautions.
https://images.2carpros.com/forum/automotive_pictures/12900_s3_5.jpg
Connect the starter motor "S" terminal wire. Tighten Tighten the starter solenoid S terminal nut to 4 N.m (35 lb in) . Connect the starter motor BAT terminal wire. Tighten Tighten the battery cable to starter terminal nut to 10 N.m (89 lb in) . Install the starter motor. Install the starter motor mounting bolts. Tighten Tighten the starter motor mounting bolts to 30 N.m (22 lb ft) . Install the intake manifold.
Jan 13, 2010 at 6:34 AM
