2000 Cadillac SLS Starting
68,000 MILES • V8 • FWD • AUTOMATIC
JAYSCUSSON
Car was running fine and then would not start. The battery has a full charge. When attempting to start the car makes a clicking sound that last longer than the key is turn.
Sep 10, 2009 at 7:53 AM
FACTORYJACK
  • 4,159 POSTS
With your battery under the seat and the ground cable attached to the body, it also has to have a good ground connection to the engine from the body. There is a short cable that goes from the body, by the rh headlamp, to an alternator mounting bolt. If your engine mount is/has been broke, this cable can break apart until it completely severs. Check that ground cable. If it is a weak clicking, you have poor potential getting to the starter. It could also have a bad starter.
Sep 10, 2009 at 3:13 PM
