2000 Cadillac SLS Engine Mounts
111,000 MILES • V8 • FWD • AUTOMATIC
YRNEH
  • 9 POSTS
I have been told that I have a bad/broken front engine mount. My question is, what is the recommendation in these cases with one bad, i.e., should I replace just the bad one; should I replace the front and rear; or should I replace them all?
Thanks.
Dec 16, 2009 at 4:00 AM
FACTORYJACK
  • 4,159 POSTS
Just replace the bad one. The front one is the mount that gets the most stress, as the engine is accelerated in forward gears, it wants to lift against it. With the replacement part, there should be a heat shield that is added, to prolong it's life. The labor has gone down on them, so ask for the labor time they are going to charge you. It should only be about an hour and a half flat rate. It used to be over three hours.
Dec 16, 2009 at 1:21 PM
YRNEH
  • 9 POSTS
Thanks for your input. The time quote that I received was 1.2. There was no mention of a heat shield. I will ask about it when I take it in.
Dec 17, 2009 at 3:14 PM
