2000 Cadillac SLS Cadillac SLS Codes: P0741 & P1860 TCC
ZMANIAK
Transmission problem
2000 Cadillac SLS V8 Front Wheel Drive Automatic 164K miles
Vehicle is setting service engine soon light for codes: P0741 & P1860
741= TCC stuck off
1860=PWM solenoid electrical fault
Both codes seem like they could be the result of the same failure however, I would like to know if I can reasonably troubleshoot this gripe with the tranny still in the car? Prob cause could simply be a short or open circuit which I should be able to confirm before obligating to a full on transmission overhaul.
In your experience, are these codes a sign of the devil?
I'm praying that is not the case; quote for repair over $4,000
Aug 31, 2010 at 10:30 AM
FACTORYJACK
  • 4,159 POSTS
Since you have an 1860 attached, it is most often a faulty solenoid(melted connector). With a P0741, it can also indicate leakage in the hydraulic circuit, a faulty converter, or both. If you could read TCC slip data, you could determine for one if it is applying, and what the level of slip is.
Aug 31, 2010 at 5:52 PM
ZMANIAK
Thanks for your reply.
How do I obtain TCC slip data?
Sep 1, 2010 at 5:19 AM
FACTORYJACK
  • 4,159 POSTS
It would have to be viewed on a scan tool.
Sep 1, 2010 at 2:10 PM
