1999 Cadillac SLS Fuel Filter replacement
1999 CADILLAC SLS
99,000 MILES • V8 • FWD • AUTOMATIC
BRADNORTON
How do I didsconnect the old fuel filter from the fuel lines?
Mar 24, 2010 at 11:15 AM
FACTORYJACK
  • 4,159 POSTS
At the rear of the filter is a quick connect, just squeeze the two tabs(usually clear) and pull the line away(cover with towel to prevent spray). The front fitting will require wrenches, the line nut is 5/8 or 16mm and the filter nut is 13/16(I might be wrong, if so it is 3/4).
Mar 25, 2010 at 3:42 PM
