1999 Cadillac SLS
MRGARCIA
1999 Cadillac SLS V8 104000 miles
its a 1999 sls northstar with dual exhuast. there is white smoke coming from both exhuast pipes, what does that mean.?? its smells like fuel is burning. also when i turn on the car it shakes or wobbles a little.
May 20, 2010 at 6:10 AM
FACTORYJACK
  • 4,159 POSTS
If you have a little misfire at start that diminishes in a matter of seconds, and you have some white smoke. You could have an internal coolant leak. Are you adding coolant? If you had a large amount of raw fuel leaking into the engine, say by a stuck open injector, it would run poor all the time, and also have white smoke.
May 20, 2010 at 4:27 PM
