1998 Cadillac SLS engine vibrate
1998 CADILLAC SLS
131,522 MILES • V8 • 2WD • AUTOMATIC
WILLIETOPGUN
engine vibrate an shake when starting up also in park the engine rises up when you press the gas pedal.
Jan 11, 2010 at 4:37 AM
WILLIETOPGUN
[quote:f273ac9d30="willietopgun"]Shakes or Wobbles problem
1998 Cadillac SLS V8 Two Wheel Drive Automatic 131522 miles
engine vibrate an shake when starting up also in park the engine rises up when you press the gas pedal.[/quote:f273ac9d30]
Jan 11, 2010 at 4:44 AM
FACTORYJACK
  • 4,159 POSTS
Don't know if this can apply to all symptoms, but it sounds like you have a separated front engine mount. It is very common on the later models(98-)
Jan 11, 2010 at 5:39 PM
