1997 Cadillac SLS oil
136,000 MILES • V8 • FWD • AUTOMATIC
PEANUT3117
my oil looks like chocolate what does that mean??
Jun 13, 2009 at 11:19 AM
FACTORYJACK
  • 4,159 POSTS
Used oil will look like dark chocolate, it is when it looks malty that an issue may be present. Is your coolant level low, or have you been using coolant.
Jun 14, 2009 at 4:35 AM
PEANUT3117
yea my coolant level is real low i refill it n it starts 2 ova heat
Jun 15, 2009 at 7:14 AM
FACTORYJACK
  • 4,159 POSTS
My suggestion would be to have the cooling system pressure tested for external leaks, and have the cooling system block tested for combustion gases that would indicate an internal leak.
Jun 15, 2009 at 2:41 PM
