Used oil will look like dark chocolate, it is when it looks malty that an issue may be present. Is your coolant level low, or have you been using coolant.
Jun 14, 2009 at 4:35 AM
PEANUT3117
MEMBER
yea my coolant level is real low i refill it n it starts 2 ova heat
Jun 15, 2009 at 7:14 AM
FACTORYJACK
✓Experienced Mechanic
My suggestion would be to have the cooling system pressure tested for external leaks, and have the cooling system block tested for combustion gases that would indicate an internal leak.
Jun 15, 2009 at 2:41 PM
