1996 Cadillac SLS brake fluid level switch
1996 CADILLAC SLS
145,000 MILES • V8 • FWD • AUTOMATIC
KENNETH RANSAW
I recently install a new master cylinder, and now I'm getting a service brake fluid level switch
Sep 27, 2010 at 12:47 PM
FACTORYJACK
  • 4,159 POSTS
Assuming that the brake fluid is full, disconnect the level sensor. If the message goes away, replace the sensor. It coul be possible that the float is stuck in the reservoir. With an ohmmeter, you can check the sensor. If there is continuity, then the sensor is indicating low fluid.
Sep 27, 2010 at 4:20 PM
