1996 Cadillac SLS
D A SWANSON
Brakes problem
1996 Cadillac SLS V8 Front Wheel Drive Automatic
How do you disconnect the emergency brake cable at the caliper so that the top caliper bolt can be removed
thank you
Apr 7, 2009 at 10:53 AM
FACTORYJACK
  • 4,159 POSTS
Are you referring to the caliper bracket bolt to facilitate rotor removal? If you remove the bolt that holds the cable 'L' bracket to the caliper, and remove the lower caliper to bracket bolt, the caliper can be pivoted upward, and you can access the bracket bolts.
Apr 7, 2009 at 3:24 PM
